Solar panel question/advice | on ElectriciansForums
Discuss Solar panel question/advice in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
J
jsmith
i currently have horse stables fitted with 4 foot florescent tubes and some out side light with i use a petrol generator to power with works well.
would it be possible to put solar panels on the roof and do away with the generator or do i have to have a electricity supply?
thanks
Hi and Welcome.
Their are "Grid Connected" and "off Grid" solar systems, the first meaning you need a electric supply the second meaning you don't, this one requires a battery backup system, in essence the solar system charges the battery's that you then use to power the lights etc.
Depending upon how many tubes you have you could also swap them for LED tubes at 18W instead of the current 36W so you'll need only half the amount of battery storage.
Also depending upon your total needs, you can consider a simple solution that charges batteries and they them power DC led lights, or if your need are greater you go for a system that generates AC and then converts to DC for battery backup, in the latter instance, you system may be eligible for Feed In Tarrif payments for the power that you generate.
How many lights do you currently power, what else runs off the genny, how long are the lights / genny on for?
I have done this and it is working well. Four LED tubes plus floodlights and path lights all off solar panel and battery system. Where are you??
Reply to Solar panel question/advice in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
