F
farmerdave
Um yes - that is the case - it isn't sideways on! Although there isn't too much space above and below the inverter, it's in a space that extends sideways and is near a bit of roofspace that is very well ventilated.
oh erm yeah I suppose that's fairly obvious now I look at it again.I guess he didn't rotate the photo, Gavin :teeth_smile:
Very good point. We received a circular from Gemserv Ltd (MCS Licensee) dated 28th Feb which included the following:
"Note that regardless of the circumstances, once an installation is properly commissioned according to the MCS standards, it is not permitted under the Scheme or the Code to
withhold the MCS certificate from the customer, regardless of whether they owe you money"
Your installer should have received the same and now you know it. It sounds, however, that it hasn't been "properly commissioned according to the MCS standards" so this doesn't yet apply.
Reply to the thread, titled "Solar Panels - cables loose on roof?" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
