Hi All
newbie to solar as mentioned before am in process of MCS approval
just wanted to check been to a job today to install immersun unit fitted quite a few units no problems,
but today found that solar company had put henley block in place for mains tails before the meter!
so main tails come from service head into henley block.
from henley block to domestic meter which feeds domestic board.
henley block then feeds solar pv consumer unit with main switch.
meter for solar pv is fed after this consumer unit.
sure this is not ok but just wanted to check?
have taken picture of this for my MCS approval next week just to check with them, also the same for the 2.5mm
in main switch that i found last week.
