soldering cables as connections | on ElectriciansForums
Discuss soldering cables as connections in the Australia area at ElectriciansForums.net
DurhamSparky
soldering cables!!!
right what would the law say if you!!!! got a connector block inserted cables into said block tightened and then filled and soldered the connector block up at both ends!!! ???????
then covered the whole thing in a nice piece of large heat shrink!!
steve
soldering cables!!!
steve
I'm not actually sure it's an approved method of solder jointing... Where Lenny when you need him?
But there again the regs only state
526.3
Every connection shall be accessible for inspection, testing and maintenance, except for the following:
(iv) A joint made by welding, soldering, brazing or appropriate compression tool.
Jim
When we were taught how to solder,one of the excercises was soldering a cable tail into a lug
Tin the cable ,fill the pot,dip the cable tail into the pot and wipe the top smooth
Excellent method for large current carrying conductors
The suggestion you have made is not very different to the above
The connector block hole to be filled by the size of conductor
As long as the conductor and connector are tinned first ,the connector block is acting no different to a solder lug and I would be happy to make such a connection
The large heat shrink bit may be the weak part of the excersise
The connector block would likely have sharp sides that could press through the heat shrink
An enclosure would be better
Could you wrap the connector in something to safeguard the wrap?
:eek:
Not the old "electricians tape" the tape DIYers believe we use to insulate every thing.
Underfloor connections, sockets, lights. One guy even used it to "bypass" the shower switch... Nice mess that was
Think the norm is heatshrink, but as Des 56 has pointed out don't think it would work well with a connector block.
Jim
Solder is a nono because the joints need to be accessable and when I was serving my the phrase was all joints must be "Electrically & Mechanically sound" and you may need to split the joints at a future date hence the conector block
Reply to soldering cables as connections in the Australia area at ElectriciansForums.net
I came across a UV steriliser tube with end caps like this while doing an EIC on a farm a few years ago. The damn thing actually bit me while I...
