SparkyDips
as above and just need a solution which is not too vulgar to terminate SWA's and then run feeds to pump and lights.
regards.
regards.
Discuss solutions for terminating pond pump and lights armoured? in the Australia area at ElectriciansForums.net
yes switched and supplied seperatly. the customer wants them hidden as much as possible, was thinking IP box in the ground but not keep on the resin/silicone to seal afterwards.
other option was mount on a small pedestal on edge of pond area with IP rated switches, armoured into the bottom then also run flex out via stuffing gland??
Out of interest does the "donor" ring have RCD protection?
yes!! claws away now thankyou!!
Reply to solutions for terminating pond pump and lights armoured? in the Australia area at ElectriciansForums.net
