G
gman67
Hi,
Hi all,
I am doing the 2391 course at the moment and I'd like to know the best solutions to a high Zs value of a circuit which does not meet BS7671 requirements. This high reading doesn't come from any damage or loose connection but due to a design mistake. The circuit is protected by a MCB type B.
I suggest:
Please tell what would be the best option in terms of good practice but also cost effectivity
Hi all,
I suggest:
- to replace the MCB with a RCBO (it's apparently acceptable but not always the best solution)
- To replace the MCB with one type C
- To install supplementary protective bonding conductors
- To replace conductors with ones with higher CSA (too expensive and time consuming)
