Some professional advice greatly appreciated here for design and costing purposes - two simple questions.
Background: We've just replaced a 25 year old wooden shed - good service but sagging a little from age and too small for our needs - with a larger one from Beast Sheds Ltd. (Recommended!).
The old shed was wired properly with an armoured cable spur from the house; a separate feed through an RCD switch box at the main house circuit board running about 8 metres out in the garden to a small 2-way (5A for lights and 13A) switch/junction box with RCDs inside the shed. I intend having the old junction box refitted in the new shed - it has had little use and is in good condition.
I know regs have changed since 1992... so before I get a sparks in, my questions are:
1) Since the junction box is effectively just on a fused spur (albeit with RCD protection at both ends) and not a ring, my understanding is that I am allowed only one twin 3-pin 13A socket from the junction box (by the door). Is that correct - or can I have a second twin 3-pin 13A socket over the workbench as we had before?
I can make do with extension cables if only one twin 3-pin 13A socket is allowed.
2) In the old shed, all the wiring was simply surface mounted on the wooden studs using cable clips over 1.5mm twin core & earth to the strip lights and 2.5mm to the sockets. Is it still OK to have exposed wiring like this or does it now require to be in plastic trunking?
(If so are there any specs/regs for the trunking type?)
Thanks hugely for a quick reply here.
(Anyone here in the Dalston or Shoreditch area? )
Best,
Reg
Best,
Reg
