P
p11jor
this is what i have down at the moment.......is there anything that you guys would add?
An earth fault is the most common fault in electrical circuits. An earth fault may consist of a circuit breaker tripping, a fuse blowing, or an RCD (neutral to earth) instantly or it may not re-engage.
The fix for this would be to do the half test method which is explained at the end of the index. The instrument I would use is an IR tester to find the fault or if there are any conductors touching. I could also utilise the switch wire on the lighting circuits for an earth fault.
cheers for any input
