someone knock me out or enlighten me | on ElectriciansForums
Discuss someone knock me out or enlighten me in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Northern Ireland
went to fit a fan this evening in a small boiler room, the boiler room has a duct about 2 meters, which just had two grills on it. so i thought id run l-n-e through 3A switched spur then l-n-e to the fan, so using the spur as a switch was my aim, but no matter what i did it wouldnt work. when i come home and try it at home it works with the switched live, permanent live, and neutral.............
does these bathrooms fans require switched live , permanent live and neutral to work??????? grrrrrrrrrrrrrrrrrr, sos thanks
went to change a broken light fitting tonight as well and the lighting circuit only had two cores l-n... the pvc seems to be degrading and you can see aluminium conductors showing through , does anyone know roughly how old this install could be?? im saying over 40 years
About 1980 ish, when copper shortage was about. Biggest problem with aluminium was a reaction between aly and copper.
Reply to someone knock me out or enlighten me in the UK Electrical Forum area at ElectriciansForums.net
