View the thread, titled "someone knock me out or enlighten me" which is posted in UK Electrical Forum on Electricians Forums.
i=p/u
went to fit a fan this evening in a small boiler room, the boiler room has a duct about 2 meters, which just had two grills on it. so i thought id run l-n-e through 3A switched spur then l-n-e to the fan, so using the spur as a switch was my aim, but no matter what i did it wouldnt work. when i come home and try it at home it works with the switched live, permanent live, and neutral.............
does these bathrooms fans require switched live , permanent live and neutral to work??????? grrrrrrrrrrrrrrrrrr, sos thanks
Noowaay man!!! Are lass is from Newcastle and Im sick of hearing her ferking voice!! lol
Theres nowt worse than a geordie bird shouting abuse at you in an accent that you cant understand. I just stand and nod :yes:
Awaay man
Jay
Nothing unusual about that now is there!
We all suffer that problem.
Reply to the thread, titled "someone knock me out or enlighten me" which is posted in UK Electrical Forum on Electricians Forums.
