Got a job fitting some bits and bobs in a house, its a new build and the people who built it butchered the ceiling, even a light weight lamp shade pulls the ceilign roses out of the plaster board, they used rawl plugs and screws and no joist in sight! when they cut open the hole to get to the cable after it was boarded, they left just a few mm that is crumbling and is not able to support the standard 6 inch pendant.
Have seen and come across wider diameter ceiling rose / pendant sets but not 100% who stocks them.
Can't get access to ceiling from above to repair as its just been carpeted throughout!
So options are wider diameter ceiling roses or put some sort of plaster ceiling rose on then screw the standard one to this, the wider diameter will mean i can screw into decent plaster avoiding the butchered edges.
Anybody know who sells the bigger / wider pendant sets or ceiling flex outlets?
