B
biffo
Hi .Brand new to this forum , so brief background ....I am in building trade and have a passing knowledge of electrical works. My family has a holiday house in catalonia with late 70's electrics .This is ok for our own use , but of course needs upgrading to modern standards if it is to be let out .
A local electrician has viewed the house and talked of complete rewiring , as well as the meter needing to be moved from the garage into a box in the front wall (is this compulsory?) As I understand it there is also no earth .
The local guy is actually german living and working in spain so obviously would only consider doing all to top spec in his own manner which would be prohibitively expensive.
So the question is would I be able to first fix re wire some of the bits (ie cooker , some sockets lay ducting and cable to move meter) and then get him to move meter , put in a new consumer unit , and put an earthing rod in ?
I have done my own first fix in UK and my electrician has been happy to sign it off .
