Special locations | on ElectriciansForums
Discuss Special locations in the UK Electrical Forum area at ElectriciansForums.net
J
joehat
I have power to a shed, would this be a notifiable still if all switches are run o my in the shed and house. I have it in conduit fm from fcu in house to double socket 10m into the shed.
I always thought it was and always notify it's, but have been told it's not as there's no switch ect outside, only in house/shed. This is a spur coming of the ring.
What are your thoughts?
I don't see why you think feeding a socket outside in a shed would not be notifiable, but a switch would be?? Am I missing something? Daz
Are you an Electrician/Trainee/Apprentice?
I still don't get the idea that something is notifiable/not notifiable depending on whether it has a switch. I can't get my head around the reasoning behind that. Daz
It used to be that you could install outside lighting to the exterior of your house without notification, but if you installed some pillar or drive over lights, they required notification though running the cable to them didn't.
Looking at my Part P approved doc (2013 revision), can't see anything to suggest that those lights are notifiable? Unless a new circuit.
Are you in England or Wales - Wales its notifiable, England its not.
Do you have a copy of the latest version of Part P? If you are a scheme member they expect you to have a copy!
No, even in Wales it is not notifiable, unless it is a new circuit.
Running a cable outside was not and is not now notifiable.
Making a connection outside (i.e. to a lamp post, electric gate, etc.) was notifiable (still is in Wales).
Reply to Special locations in the UK Electrical Forum area at ElectriciansForums.net
Outside socket… ok. But you say the fcu for boiler is beside the outside socket… is the boiler outside too? FCU’s have an IN and an OUT… the OUT...
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
