speed control | on ElectriciansForums
Discuss speed control in the USA Electrical Forum area at ElectriciansForums.net
PaulB54
New Hampshire
I have an old vacuum motor that is 110V, 8A
It is way too fast. I need to slow down the rpm's.
Can I use a regular ceiling fan/light dimmer switch to do this?
thanks
P
thanks
P
Dimmers are designed for resistive loads, your motor is an inductive load.
I suspect this is a universal motor which are commonly fitted to vacuum cleaners. Ideally a universal motor needs a load to limit it's ability to run at over speed and this is achieved in a vacuum cleaner with the fan, without a load it can run to a point of apparent destruction. You must also consider how the motor is cooled, within a vacuum cleaner this is done by the air being drawn over it and you will notice expelled air becomes warm quite quickly.
Your motor has been removed from the vacuum cleaner hence it no longer has a load or a means of cooling.
thanks
P
I would suggest you forget this, never heard anything like it either, if the "old" motor isn't up to scratch then buy one that is
Reply to speed control in the USA Electrical Forum area at ElectriciansForums.net
You are quite welcome my friend and good luck. I wasn’t trying to insult your intelligence and sorry if it seemed that way. Have a great day
If you have to option of altering the wiring to separate the light and fan supplies - then there are DIY options possible. One involves some...
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
