Spike ground lights | on ElectriciansForums
Discuss Spike ground lights in the UK Electrical Forum area at ElectriciansForums.net
byzar9
Mansfield
Hi there, I'm looking for advice!
I will makeover my front garden and I want to install spike ground lights! Why I want to do this, I have a little bit of knowledge and always I want to do the safest way! I've contacted several electricians and they quote me around ÂŁ400-500 for the job!
I will use ho7 cable for the spike ground lights, see picture attached, I want to buy the set of lights, because they are gu10 bulb and I want to wired them inside of the house with a smart socket.
I will use those waterproof conector, any advice is welcome! Thanks
[ElectriciansForums.net] Spike ground lights
  • [ElectriciansForums.net] Spike ground lights
Get stuff from a reputable supplier. They are less likely to sell poor quality gear and you have some come-back if it proves to be rubbish.
Do you really want ground mounted lights? What sort of illumination are you wanting to achieve?
If you are plugging it all in to a 13A socket in is feasible to put in adequate outdoor cable like 1.5mm 3-core H07RN-F and some waterproof junction boxes, but please get good quality stuff and take care to terminate the cables properly.
Also make sure your sockets are RCD protected, and make a habit of checking the RCD via the test button at least twice per year.
Reply to Spike ground lights in the UK Electrical Forum area at ElectriciansForums.net
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
As littlespark says there's no ways you're going to find spike lights that can accomodate SWA cables directly into them.
