Spirit Level Set Recommendations | Page 2 | on ElectriciansForums
Discuss Spirit Level Set Recommendations in the Electrical Tools and Products area at ElectriciansForums.net
Most levels are accurate when new, but it's whether they're still accurate after a few knocks that matters.
Also need to take into account what you're using it for. If it's to run a piece of conduit up a wall from bottom to top, then it doesn't matter too much if it's 10mm out overall, but if you're using it to set a door frame, and that ends up 10mm out of true, you're going to be looking for lozenge shaped doors to fit.
Don’t do what I did 25 years ago and have the genius idea of G clamping my level overhanging a desk to support 4 x 100m drums of singles…..! Some of the level was level after that idiotic mistake…
I graduated to a broom through a step ladder very soon after that!
I never use a level for that sort of work. plumb line is far more accurate. can gauge to 1mm.
That’s good advice that Tim. Thanks. I think the Magnusson set for £40 is a decent buy. I’ve already priced up a laser that’s been recommended. It’s by Kaiweets.
i have had the magnusson set for ages. only 2 left out of the 4. can't fault them for accuraccy or walking ability.
I bought the Bahco set and they lasted me less that 6 months. They're not very robust and if you've got a bent level, it's less than useless.
Admittedly they did on occasion bounce around in the back on the van, but no serious abuse.
Reply to Spirit Level Set Recommendations in the Electrical Tools and Products area at ElectriciansForums.net
