split concentric cable | Page 3 | on ElectriciansForums
Discuss split concentric cable in the UK Electrical Forum area at ElectriciansForums.net
ExArmy
cumbria
was reading an article in PE today about split concentric cable and it got me thinking......
.....why am I not using this more often? it's much easier to work with!
Tied on tray up a riser cupboard above ceiling in apartment drop down to distribution board in studded wall more than 50mm no rcd required you can only use 16mm t&e on certain cable lengths
so concentric for me
Sorry to drag up an old thread but I'm intrigued by this point. What is the reason for being able to use concentric on longer runs than t&e? Daz
I have never used concentric outside of the DNO , used it a lot for the DNO ,split and straight , the central core has always been ally solid conductor , I didn't know it was available outside , i just never had to use it outside , on the contracting side we always had to use SWA ,does the concentric available generally available have the same make up with a solid central ally core or what , I must admit that is reason I thought was a cable only for DNO use ,
Reply to split concentric cable in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
True. Although I'd hazard a guess that things like woodworm treatment are probably chemically quite similar? Don't know.
