Split load CU cable CSA | on ElectriciansForums
Discuss Split load CU cable CSA in the Australia area at ElectriciansForums.net
Amp David
Mentor
Glossop
In a regular single phase consumer unit, what CSA is the cabling that connects upp the RCDs to the nuetral bars and main switch?
Asked that question before no one gave an answer but if you are thinking of upgrading a CU then you can get whats called a split load kit from the wholesaler. If I remember correctly it was Lenny that came to the rescue with that one.
Chris
Reason for asking is so I can get some ferrules to fit. I like to trim the cable so that it terminates neatly without any copper showing. If the ends are cut they can sometimes be a pain to get back into the terminals.
Reply to Split load CU cable CSA in the Australia area at ElectriciansForums.net
I would probably C3 it, based on no contact with sharp edges, all the terminations being tight, and no signs of any thermal damage. With all...
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
