I think √2 comes in to it somewhere doesn’t it Dave?
I don’t think we’re wrong, but you never know.
240V RMS = 339.41V peak→base line.
Well isn't that pretty! I think it's going to peak at a bit more than 240V though.
You could easily create that trace on an oscilloscope screen, but it's not an accurate representation of what is going on.
was a rough representation so I used RMS voltages it was my representation of what I thought I would see would you like to draw it please
You used peak→base line which would give 169V RMS.
I did the drawing years ago and it's on photobucket for use elsewhere.
Gotta be quick around here, there's always some smart-arse apprentice looking to score a point off the boss!
True, many years ago I was the apprentice. I also got my arse kicked when I got things wrong.
I worked with some real old barstewards, learnt a lot from them though.
Up until about ten years ago I still phoned my old foreman for a chat. At 85+ he told me where to look for a fault in a 2000HP motor he’d never even seen. He was spot on the mark.
Can’t phone him now, R.I.P. Ted
Its called the crest factor, and it takes you from peak to RMS, although under certain condtions(Fault) the crest value can be greater.
Stop playing the smart arse. Learn about transformer phase and vector diagrams.
Okay, if the vectors are in phase, or 180 Degrees apart you get the same answer, though from reading J & P transformer book and other publications they state 180 degree, some were 90 degree.
Cheers
FFs its centre tapped there would be a sine wave above and below the base line
take 2 comming in a mo
Take three
For the "in phase vectors" to add we need a series connection within the Tx, this isnt the case, and it the vectors were 180 degree apart and wired in series they would subtract.
The Tx is center tapped, extract.
Center-tap transformer. The tapping point is in the exact center of the secondary winding providing a common connection for two equal but opposite secondary voltages. With the center-tap grounded, the output
V[SUB]A[/SUB]
will be positive in nature with respect to the ground, while the voltage at the other secondary,
V[SUB]B[/SUB]
will be negative and opposite in nature, that is they are 180[SUP]o[/SUP] electrical degrees out-of-phase with each other.
Now VA= NA/NP * VP
VB= NB/NP* VP
230 at 0 Degrees plus 230 at 180 degree = 460 Volts
Take four
If we have a winding that delivers 480 volts, we earth one end(0 V and reference) and tap 1/4, 1/2 and end we would measure 120 v, 240 v and 480 v all in phase from that reference.
If we center tap the winding and earth(0 v and reference) what we would see is at the end of one winding 240 + and the other end 240 -.
So the two phases from the center tap reference are 180 degrees apart.
Cheers
Your just not getting this are you. Convention with transformers is governed by angular orientation of the windings not the output waveform.
I’m not continuing this further on here due to constraints imposed on me by the moderators.
90° phase displacement. Explain for the other members.
Split phase
Commercial Electrical Advice
Thread Tags
jimmer,
Leyland30,
