Y
Yorkie
I need a separate supply for the ring main in my garage (where the CU is located), because whenever something trips the RCCD in the CU I have to wind up the garge door by hand to get to the CU and reset, which is a pain. It takes ages to find the winder handle, usually in the dark and I'm not getting any younger.
I'm trying to spec the job properly before getting a sparky on the job and I'm keen to know exactly what's what. TBH, the last chap who replaced the CU 7 years ago goosed me quite badly and it ain't going to happen again.
I've already sourced a separate 2 position CU with a 63A RCD, plus a 32A MCB and a 6A MCB for the Christmas lights, all for free. I was expecting to be asking for the incoming 25mm tails to be split with a Henley Block and then feed the old and new CU separately. But when I cracked open the new CU to check it out for mounting requirements, it looks like the incoming terminals are 10mm max. Not even a chance of putting 16mm in, which is the size coming out of the meter to the 2 pole isolator. It's then 25mm through the wall to the CU.
So what are the options? I could ask for it to be fed from the main CU via a 50A RCD (for which there is space on the main breaker), but the problem is if a light bulb blows it can take out the main 100A breaker, so I'd be no better off than I am now. It's a split CU, with all the rings on an RCD, all the lighting circuits just on the 100A breaker covering the whole box. It's usually a light bulb going pop that causes the problem.
Are we allowed to have a 10mm supply coming out of the Henley Block to the new CU? I don't know what size the main fuse in the supply box is, but the carrier is 100A. There's no need to crack it open for isolation and I'd rather not bother with all the hassle of getting the YEB in to find out and re-seal it. Something tells me that in the worst case, 100A fizzing down a (short) 10mm cable isn't going to be allowed, but I need some advice please. Even if it's allowed, it would only be single insulated so how to we ensure that it is properly safe?
Wha'd'ya think?
Wha'd'ya think?
