Split Suppy Advice Please | Page 2 | on ElectriciansForums
Discuss Split Suppy Advice Please in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for the replies so far. My son-in-law is a sparky (but industrial, not Part P registered) so I'll get him to pull the lid off tomorrow and I'll take some photos.
Thinking back, when the CU was fitted the brand new 100A breaker was duff, wouldn't latch, and he had to fix something up for a day or two until he got a replacement (hence the reason for me getting goosed and over charged for labour). Maybe the replacement wasn't too smart either? I'll think about having it swapped while we're at it, just to be sure.
The consensus seems to be that if the switch is okay, just get the new CU fed from an RCD in the main CU. If so, what size should I ask for, is 50A big enough?
I think photos would go a long way in getting better advice. Surely if your sons a sparky you could persuade him to install an RCBO for your garage circuit and take it off the RCD. Threaten to torture him with some childhood photos....it always worked for me when my parents did.
Update............... I'm glad I'm not doing the job myself.... .. 'cos I'm a berk.
Of course the new CU will take 25mm tails - they go into the RCD, not in the neutral rail. Agghh!. So all's well. :oops:
But of course, if all is well in the main CU, is it best practice to split the tails and feed each CU separately, or just to take it out of the main CU on a big ol' RCD (not under cover of the RCD that's in there)?
I don't mind spending a few quid extra so long as it's as good as it gets.
Always an option, but I thought is was notifable work and he can't Part P register it?
I keep threatening to sponsor him to get accreditation, but the problem is that business is so good there's never any time. In any case, if the cables aren't as thick as your finger he's not always too interested!
Reply to Split Suppy Advice Please in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Haha yes, it is. Must be a northern expression. Have a Google 😂
This is the point of having a trainee badge... it allows you to ask simple questions without the critism reserved for have-a-go heroes. Things...
