Guest viewing is limited
View the thread, titled "Splitting 2 lights" which is posted in DIY Electrical Advice on Electricians Forums.
R
richardsim7
Hello,
So I've got 1 switch that controls 2 lights, and I'd like to change that to a 2 gang switch so I can control them individually.
This is a diagram of the current setup:
I used a tone generator to trace the wires as access to the ceiling is pretty impossible.
Someone pointed out that wire 4 might be the switch wire instead. If that's the case, here's my proposal:
Is that correct?
Cheers,
If some bright spark on here can make head or tail of that little gem of a circuit diagram I will take my hat off to them
Just one question
How many cable cores do you have at the wall switch?
Just one question
already seen it Des..
playschool stuff...
Oh I know, it's proper special :4:
1 cable (2 core and earth) at the switch. So I'll have to run a 2nd cable...
You could always go wireless
Regards the circuit diagram and come to think of it,does Lowry ring any bells
It could be art and me being the un-arty type I may have been barking up the wrong tree
Reply to the thread, titled "Splitting 2 lights" which is posted in DIY Electrical Advice on Electricians Forums.
