Splitting of UFH and Rads via Stat | on ElectriciansForums
Discuss Splitting of UFH and Rads via Stat in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Burton
Good evening.
Finally the futility of the design of my heating system has led me to try and alter it. Central heating is something i'm not brilliantly versed in.
To keep it short, presently a BG WR-1 wireless clock controls the rads and the manifold via the switched output, powering up to the boiler with a flex and down to the manifold. The result is that when the ever hotter UFH reaches temp, it turns the whole system off. The stat is currently in the downstairs with the UFH, split into 3 zones. Moving the stat upstairs had a slight improvement, but it's not perfect.
This setup is leaving the upstairs freezing most days.
What I would like to do, is use the current system just for the upstairs rads, and add a separate clock for the UFH. I have had minor success in an attempt of adding another spur for the manifold to power it independently, however the valve powers off of the WR-1, so water flows, but doesn't heat up. My idea was to just use an immersion timer for the manifold, hoping that the manifold had the capability to call for the valve and pump etc.
Will it be possible to connect something to the call wire in the existing system, so that the boiler heats up the water for the manifold independently? Can this be done purely electrically?
In my mind it should... but I may be wrong.
The outcome I'd like is to have the UFH kick in around 4am, for a few hours so that its warm when I come down around 6-7 (it takes a while to take effect) and then as norm, have the rads turn on around 6, which obviously can only be done via two different clocks. Presently the lot comes on around 5:30 which isn't ideal for us.
Attached is some pictures. The clock is the Wr-1, 3 I believe 1 is the Common and 3 is 'Call'
The boiler is right above all of this. Manifold is the Emmeti ewc-1, 4 zones in use off of 3 stats.
Any help or insight is greatly appreciated.
Thanks in advance.
[ElectriciansForums.net] Splitting of UFH and Rads via Stat
You can either try and get a plumber and electrician to create another heating zone or use something like the honeywell evohome.
It sounds like a right balls up of a design. Get a decent heating engineer / plumber to look at it and zone it properly
I know. There's a few things around the place I wish could have been done differently in hindsight had I have known more about it all at the time it was put it. ( I started training about 2 months after the renovation was complete)
I think it may come to that, but i'm hoping that I with some research I can find a solution to do myself to avoid the cost, or some of it.
The simplest way to have control of rads and UFH separately is to have two 2port valves installed one for the UHF and one for the rads. You don’t say what type of boiler you have I.e combi or system boiler but either way it’s pretty straight forward.
The UHF would control one valve which in turn would fire the boiler and a seperate timer or programmable roomstat would control the second rad valve which would also fire the boiler. Two valves is by far the easier option to control two heating zones. Just a slightly modified s-plan really.
Could you replace the stat for the ufh for a programmable stat that allows for calibration of the temperature on that zone alone so you can set it to be more in line with the other stats temperature?
Am I correct in that you have stats for each of the UFH zones if so are they just stats or time clock /stats. And this valve operates all the heating ?.
The impression I get from the OP is that only one valve controlling heating (rads nd underfloor) so only possible way for this to work independently of in another is to install two motorised valves, heating/hot water. And in a perfect world 3 programmable roomstats for each UHF zone and a separate programmer and stat for rads or another programmable room stat. If as I presume the system is plumbed as one circuit rads and uhf together no way to seperate them. Plumbing alterations required I’m afraid.
Yeah this is how i feared it would be. You are correct, the UHF has 3 room stats for the zones.
I'm 99% sure this is how it's been plumbed. Gonna have a mate pop round and take a look to see what he thinks, none of the plumbing is accessible, is the problem, so unlikely we can afford to rip the kitchen out for this.
Thanks for the help guys.
Any system that I have worked on has had programmable room stat per zone opening each of the manifold valves and a volt free switch to boiler the wireless room stat transmitter should be in the coldest area upstairs where the heating is via rads the valve operating rads only.
Yeah that's how i assumed it would be, but upon testing I could get the manifold to send water to the zones downstairs... but it would only turn hot when the rads where turned on via the clock... but this was just by operating the manifold with and live and neutral, and not sending any commands to the valves etc independently of the rads' timeclock.
So the valve has to be open and the rads upstairs on if you need UFH on. Hopefully it could just be the way it is wired. Have you got any photo's of the plumbing around the valve and the UFH control centre.
Reply to Splitting of UFH and Rads via Stat in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Get better soon
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
As per Davesparks, it would be helpful to see a picture of the valve etc. If the manifold valve referred to is a common or garden motorised...
Thanks I understand it now just getting to grips now with the different types and different ways of wiring them
