L
leighgainsley
Hi guys
I am converting an existing semi detached house into 2 flats. The house once converted will have a 1 bedroom flat at ground floor and a duplex 2 bed on the 1st and 2nd floors. There will be a small 5 sqm communal area as you come into the house with the doors to each flat off this communal area.
The exisitng house obviously has an existing single phase electrical supply.
I have had conflicting advice as what to do with the electrical supply. Some people have said that I will need a new three-phase supply into the house and I have a quote for this from UK Power Networks of £2750!. According to UK Power Networks I can not have 2 single phase supplies as there is a communal area rather than a door to each flat from the street.
However, after speaking to my electrician this morning, he has said I can just keep the existing single phase supply and split it once in the house? Is this possible? It will oviously save me a small fortune!!
I plan on selling the flats so will need to comply with all the building regs etc.
Look forward to hearing!
Many thanks
Leigh
Ok. Just spoke to them. Apparently UKPN will not spur supplies. They have a separate supply for each property. Its one meter per a supply and thats it.
So I then asked for just another single phased supply which they have agreed to quote on.
Amazing how they just seem to change their tune! With a bit of luck this might save me around £1000.
Thanks guys
Splitting semi detached house into 2 flats
Australia
leighgainsley,
leighgainsley,
TrueNAS JBOD Storage Server
