Spot light wiring placement... | on ElectriciansForums
Discuss Spot light wiring placement... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Barnard Castle, UK
Hi everyone, I'm hoping someone here can help. I recently did some carpentry work for a new customer and I noticed their electrician had just replaced a single pendant lamp with around 8 spot lights. Under each ceiling joist the electrician had removed a small strip of plasterboard, around 100mm x 20mm, and passed the cable directly under each joist from light to light, effectively within the plasterboard depth. Is it allowed under the current regulations to run the cable directly under each joist, within the thickness of the 12.5mm plasterboard, or does it still have to be at least 50mm from the ceiling surface?
Many thanks in advance
Kev
I don't like the sound of what they have done, i think it is lazy.
however sometimes you have to do what the customer wants and they may not have wanted floors lifted above so the options are limited.
if the circuit is protected by an RCD then i cant see a problem with the regs.
Thank you for the replies. The room is the bottom floor of a 3 story house, maybe 5 years old. I presume everything is rcd protected given the young age of the house. The ceiling is being re-skimmed. I'll try and attach a photo of the wiring if I can get it to upload.
If it's legal and to the regs, fair enough. Just didn't look how I'd seen other wiring done.
  • [ElectriciansForums.net] Spot light wiring placement...
Reply to Spot light wiring placement... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Of course, showing my age now!
An example of the long term race to the bottom of quality of work in our industry, IMHO.
