Y
yipee458
My downstairs hallway, Front Room and Living room are running off a 6amp mcb. In each is a 11w energy saving bulb. In the Front room i have installed 12 50w halogen spot lights on 1 dimmer switch all with dimmer bulbs. after installation all was working working fine as it was tested for a few minutes at a time. then came the problem. As i came to paint the room, the lights were on for a while and after a couple of hours began to flicker. when the switch is turned full they seem to be working fine its when i turn it down they flicker quite fast. when i leave them off for a while it goes back to normal then problem starts again. No bulbs have fused nor has it allowed the mcb to trip.
Any advice guys???????????
