Spot Lights Flicker | Page 2 | on ElectriciansForums
Discuss Spot Lights Flicker in the Talk Electrician area at ElectriciansForums.net
i have a dimmer that will dim any type of lighting going. it's american, made in tennessee by jack daniels
other way around (not all dimmers are suitable for halogen lighting)
Resistive
These are designed to control lamps that have a filament, which emits heat and visible light. Typical lamps are standard GLS incandescent, Mains halogen.
Inductive
These dimmers are designed to control light sources which use wire wound components in the form of transformers. An example of this would be low voltage lighting.
I've never come across dimmers that will operate a linear resistive load but won't run an inductive load although there may be a derating factor involved.
Reply to Spot Lights Flicker in the Talk Electrician area at ElectriciansForums.net
Neutral and live
You as well! Popcorn and beer on hand plus a day off, I'm ready! :)
