Spot lights? | Page 2 | on ElectriciansForums
Discuss Spot lights? in the Australia area at ElectriciansForums.net
dexstar
Got another little question for you, it spot lights this time! Here is the dilemma the house i am working on she wants four spots on a dimmer and on another circuit 4 wall lights on a dimmer. What rating do i need for the dimmer and how do you work it out? also what spots should i use? do you reckon normal cheap ones and remove the insulation from around them, i looked in the regs and it says up to 100w a area of 0.5m around the fitting. Can i use normal spots in the bathroom? and one last thing there is one spot in a quite height restricted area should i use a fireguard one for that?
Sorry for all the questions!
I love voltsticks!!!!! Takes me back, the first big shock I ever got!!!!!! (well 2nd really, Cathy and the wonder bra at tha back of the roller rink)Cant believe you can still get them!
And Volt sticks!
Reply to Spot lights? in the Australia area at ElectriciansForums.net
Try using the switch You can try the Touchdim function, remove the dimmer switch and use a retractive switch, like a bell switch to control the...
