Spot the error in this, then. | Page 2 | on ElectriciansForums
Discuss Spot the error in this, then. in the Australia area at ElectriciansForums.net
Rockingit
Mentor
Supporter
V.Nearly Esteemed
Somerset
OKaaaaaay.....I see, sort of, where this is going, but 514.4.4 says that other conductors shall be identified in accordance with table 51, so I really don't think it holds up given that if it's not a single core then it has to be 'another'. TBH, it's a bit of a pointless debate.
I didn't intend it as a debate
I read the thread and the possible intention of you going to trading standards on this issue
I thought it would be imperative for you that the complaint was justified with this particular issue
The reg quoted has a different interpretation to your own by others
Whether these practices are adopted by us or no, it could have rebounded on yourself if the designers of the system had mentioned it was not aginst the regs
I see this type of wiring quite regularly. Where 3 core flexible cable is used to supply class II equipment such as PIRs . The Grn/Yell cpc gets substituted for the switch line.
Its not particularly good practice especially when published as exceptable by a manufacturer !
I would strongly suggest that you kick up a fuss.
Taken as gentlemanly, and scholarly, concern. Thank you. I'll probably just leave it to a gentle nudge of a chat with their technical director to suggest they amend the drawing. Have enough battles on my plate at the moment as it is!
Reply to Spot the error in this, then. in the Australia area at ElectriciansForums.net
I've been using the Fusion ones CEF keep. They are reliable and not overly expensive. Just need a L&N to one end cap. They come with a replacement...
H
Adhesive not gone off Got myself a pallet of adhesive (check other thread for make) and got it at a good rate, hence why i bought a pallet...
Handyeire
H
