Spot the Fault | Page 2 | on ElectriciansForums
Discuss Spot the Fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It 'goes over the edge' of the flat roof crossing the middle of the left hand puddle in the middle of the picture! Drops to the 'ground', lower flat roof, to the right hand side of the far left air con unit.
Not on the picture I'm looking at
Forum has shrunk the picture.
It starts from the top of the pic above the single window in the middle.
Can't see where it goes near the AC units at the bottom.
right cliked. no option to view, only copy, save, inspect element etc.
Have you got "view image in a new tab"? or someting like that Tel? You'll be able to zoom in on it then.
Careful mind, the tedium might be too much for you as even zoomed in it looks thinner than a human hair.
Reply to Spot the Fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Did a fuseboard change yesterday from an old wylex board to dual rcd on a TT system with 14ohms ZE and finished pretty late. Went back this...
