Spot the mistake ! | on ElectriciansForums
Discuss Spot the mistake ! in the UK Electrical Forum area at ElectriciansForums.net
JD6400
Mentor
I went to look at what supply we had to work with , for a new grain store that one of the local agricultural dealerships , who we work with is quoting for .
Can you spot the mistake !?
[ElectriciansForums.net] Spot the mistake ! [ElectriciansForums.net] Spot the mistake !
  • [ElectriciansForums.net] Spot the mistake !
It could do with a bit of a clean up but I have seen worse by a long way , and yes the rcd is before the meter .
It is in a old Hosier prefab milking parlour , which is pretty much just a big tin shed .
I like it how the meter boys have been in and fitted a new meter and what looks like a new fuse and carrier , and sealed all of their gear back up , but just walked off and left the old rcd in line without a second thought !
Is the isolator before the meter an actual rag? I thought it was just a DNO specification to stop 'tap offs' before the meter.
I would say that you are correct , but then again being on the company side of the supply it is out of bounds for us anyway .
I wonder if , even resetting it after a trip could constitute tampering !?:willy_nilly:
Reply to Spot the mistake ! in the UK Electrical Forum area at ElectriciansForums.net
That explanation would make a lot of sense and would certainly explain the new bases and new boxes, with old relabelled alarm heads. I do remember...
Not sure if they were unique but they did not incorporate a thermal trip it was all magnetic.
