Spotlights and kingspan insulation | on ElectriciansForums
Discuss Spotlights and kingspan insulation in the UK Electrical Forum area at ElectriciansForums.net
smiffy911
What do you do when fitting spotlights in celings if the builder is installing kingspan insulation between the joists. I know there isn't really an issue with heat dissapation as I now tend to install LED's. Do you install cables and normal, builder installs kingspan and plates the ceiling, then once plastered cut hole through ceiling and insulation and hope your cables are still there. Or do you have any other ways of installing?
Quick question while on the subject, how do you earth a spotlight without a earth terminal or earth lug?
Or do you not bother?
you don't . the lamp holder is not connected to the fitting metal so it's class II
I use Hager or Line junction boxes on each downlight. T&E between the JBs allows CPCs to be continuous in circuit and be properly terminated. Then a length of 2-core 0.75mm heat resistant flex (about 9-12" normally) from each JB to each downlight.
I use Hager or Line junction boxes on each downlight. T&E between the JBs allows CPCs to be continuous in circuit and be properly terminated. Then a length of 2-core 0.75mm heat resistant flex (about 9-12" normally) from each JB to each dowlight.
exactly as i do. except i generally use 3 core flex but snip the cpc. can't be arsed carrying 2 core and 3 core flex.
and make sure bob the bodger ( sorry, builder) leaves your cables in the hole in the kingspan. otherwise he's going to need to do a lot of ceiling patching after you've found the cables with a lump hammer.
Evening All. I have never used any of the line JB's as of yet. I often use the hager downlight junction boxes, i am interested to get your input on these Line junction boxes are they good/worth trying. Thanx
Reply to Spotlights and kingspan insulation in the UK Electrical Forum area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
If you have a plan for the downlights, and all you are doing is cutting out and fitting them then yes, 8 downlights in 4 hrs is slow. Fixed price...
