Spotlights and kingspan insulation | Page 2 | on ElectriciansForums
Discuss Spotlights and kingspan insulation in the UK Electrical Forum area at ElectriciansForums.net
smiffy911
What do you do when fitting spotlights in celings if the builder is installing kingspan insulation between the joists. I know there isn't really an issue with heat dissapation as I now tend to install LED's. Do you install cables and normal, builder installs kingspan and plates the ceiling, then once plastered cut hole through ceiling and insulation and hope your cables are still there. Or do you have any other ways of installing?
dog's danglies, mate. can even do loop in at first fitting using the connectors supplied with the lighting enclosures. loads of room inside the enclosures.
You're out of date Kingeri
1mm is the minimum for lighting now (1.5mm for everything else).
Laurie
Then a length of 2-core 0.75mm heat resistant flex (about 9-12" normally) from each JB to each downlight.[/QUOTE]
Laurie
[/QUOTE]
Reg number for this? You can happily supply a fixed load with an appropriately rated cable. The 0.75mm flex is feeding only one light fitting.
Reply to Spotlights and kingspan insulation in the UK Electrical Forum area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
If you have a plan for the downlights, and all you are doing is cutting out and fitting them then yes, 8 downlights in 4 hrs is slow. Fixed price...
