View the thread, titled "Spotlights Wiring Advice" which is posted in Australia on Electricians Forums.
W
whinswood378
Hi.
We have been given some new spotlights for our kitchen... but I cannot find any L or N symbol to indicate which terminal is live and and which is neutral. They are double insulated so do not need an earth connection.
There are some symbols that I don't recognize. One side has the letters VEM and the other has a symbol that looks like a ''Devils Fork'' in circle.
These spotlights are ''Knightsbridge MD02 R80''
Please help...Thanks.
Keith.
not easy. that's why you will see so many comments to call in a sparks. usually, by the OP's posts, we can get a rough idea of competence.
those fittings i believe are not fire rated, you would need to fit hoods above, personally i would not fit them, go for a decent fire rated fitting then you have the option of LED which will save you a fortune on running costs, dont forget electrical works in the kitchen is classed as a NOTIFIABLE location
Why do you need fire hoods? (Assuming the OP has a single occupancy house and not a flat)
No need for fire rated fittings as in a single dwelling there are no fire compartment boundaries other than above an integral garage.
Where can i find this exact info in building regs? this was my thinking, but i am about to go head to head with a jobsworth BCO!!!
Follow the link,search for wiring matters spring 2005 and download the first on the list
There is a section on recessed downlights and the report of a consultation into the effects commisioned by the IET
Read the comments on the report fully
Home - IET Electrical
Reply to the thread, titled "Spotlights Wiring Advice" which is posted in Australia on Electricians Forums.
