Spray Paint Oven | Page 2 | on ElectriciansForums
Discuss Spray Paint Oven in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I agree with Engineer54 that they need testing, but I still maintain that fixed wiring is what we test using the standard electrcial certs equipment just is not covered , non of the certs we use cover for equipment testing
Reply to Spray Paint Oven in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
