Sprinter theft no key | on ElectriciansForums
Discuss Sprinter theft no key in the UK Electrical Forum area at ElectriciansForums.net
Yozza19
Patron
Liverpool
Had my 2017 sprinter stolen the other night in Liverpool withought the key
I managed to find the van with all my tools tester ect missing but all sorts of crow bars and sledge hammers in the back
It was on false plates to 64 plate
No glass had been smashed but front 1/4 window seal had been removed
To gain access they stole it at 12:05
And had removed the tracker by 12:12
Apparently there so easy to steal under 4 minutes only way to stop them is the old fashioned disc lock
Ford transits are the same mj Quinn had 34 vans go in a week 28 sprinters and 6 transits so be carful our there
With a lot of the modern vans i am told by a police officer that if they can get access to the obd port then they can plug a little machien in and then programme a blank key from online. they just need to carefully open the window or if brazen they just smash window and do it quick when on a remote unwatched location. If they are out thieving on your front drive they will do the stealthy slow method... you can get littel devices to block off the obd port.
Could I be forgiven for thinking the car manufacturers are on a promise from the tea leaves? I humbly submit there is no compelling reason for obd port to be able to access the car's security subroutines (should require cpu removal). And then the whole repeater method of theft for keyless entry cars - what were they thinking when they set it so the key is always transmitting? It's a bit like clothes dryers without thermal cut outs ...
Forgive me for being a bit archaic but how did they get round the steering lock? I agree with the later posts though, it is beyond belief that you can do all this from an easily accessible computer port. The people that design these systems must be daft, or not particularly interested in security?
Well you did park it in Liverpool overnight with all your tools and testing gear your asking for trouble...?
What were you expecting ?
They don't need keys they just peel back the slide door like a sardine tin or cut straight through the metal and peel it back.
Can you ask him if they can do it to an 08 plate Vauxhall Combo?? Hopefully this isn't a "modern" van......
Reply to Sprinter theft no key in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
