Sav
Hi guys,
just a quick bit of advise needed please.
Just went to see a minor job and this is what the guy wants.
To add a double socket in his loft.
There is no other sockets there and the only cables are the lighing ones and a 6mm shower cable.
Now, would you or could you spur off the shower cable with a 13amp fused spur, and run a 2.5mm to a double socket??
The shower is has a 45amp mcb and the fused spur that I am putting in, is an RCD unit.
I advised him to come off a socket in the room below and feed the socket in the loft, but he does not want trunking in the bedroom, or the wall to be chased.
Thanks guys and take care,
Sav
Sav
