W
weston29
Hello all, is it possible to supply a single phase socket 230v outlet via a fused spur from a three phase and neutral supply? It is a job i've come across whereby the 230 outlet needs replacing because its damaged (metal clad thing thats had a clout and is hanging off). The supply now is from the red phase of an adjacent three phase isolator and subsequent neutral. The customer nearly fainted when i said it may need its own seperate supply as it is a huge cable run which will cause major disruption to his workshop as the conduit run is buried behind all manner of machinery which looks impossible to move.
Had a look at the regs and cant seem to find anything on it? Any ideas chaps please let me know.
