Spur off a power breaker | on ElectriciansForums
Discuss Spur off a power breaker in the UK Electrical Forum area at ElectriciansForums.net
London
Hi all.
I currently have a double socket with 3x wires in the back. One set is going to a single power breaker ( which then goes through the wall). Not sure what it does or protects as it came with the house. I wanted to spur off to a single socket behind the tv. Would I be better changing the breaker to a single plug and spurring off that or chock blocks and a blanking plate....... or nothing.
[ElectriciansForums.net] Spur off a power breaker
The power breaker was put in to give rcd protection to something. You don’t know what it supplies?
What is on the other side of the wall? Outside socket, shed or is it interior? Whirlpool bathtub or something?
If the whole house is rcd protected, or at least just the circuit in question, then the power breaker can be removed and a switch fused connection unit put in its place.
You could connect the tv socket to the output of the spur alongside the cable going through the wal. Not a huge additional load.
only advice i can give ( and i think everyone else would say same) is to get a local electrician in to see what's what, and the safe way to do what you need.
Reply to Spur off a power breaker in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
Please use the like button to thank, like or whatever. As the forum treats that as a positive message then and uses it to score members.
    • Optimistic
Thanks for all your input guys. It seems to be that it’s down to personal preference on the best thing to do/if it’s appropriate. In my head I...
