Spur off a Spur, extra sockets? | Page 2 | on ElectriciansForums
Discuss Spur off a Spur, extra sockets? in the UK Electrical Forum area at ElectriciansForums.net
Diy592
Scotland
Hi,
Wanting to have an extra double socket and a single socket installed in my kitchen.
Getting mixed answers whether I can take a spur of another spur, I have attached a picture of what is required. One socket if for a dishwashers the other is for above worktops.
Advice would be appreciated?
[ElectriciansForums.net] Spur off a Spur, extra sockets?
Hi,
Thinking about adding to the circuit now? (picture attached). In the photo the red wire that is being dicussed fell out.
Yes this is what I meant in my reply remove the short link between D.P. switch and single socket extend ring but as said you will need to confirm ring the assuming that you are burying the cable in wall also sockets used by ordinary persons RCD additional protection will be required.
Citcuit is RCD protected, I am a DIYer, I think it on the ring I can follow the cable under the floor to next plug?
Hi,
The whole job is pretty simple if you know what your doing. Just Prove its a ring circuit. Open the ring circuit to incorporate extra points and DON'T cut through the cooker switch load.
The only question is................... Do you know what your doing? If in any doubt at all get a professional to do it.
Reply to Spur off a Spur, extra sockets? in the UK Electrical Forum area at ElectriciansForums.net
J
The rcd spur being fitted is probably because there wasn't rcd protection of that supply.
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
