Spur to an outdoor light, from a ring main | Page 2 | on ElectriciansForums
Discuss Spur to an outdoor light, from a ring main in the UK Electrical Forum area at ElectriciansForums.net
T
tomma
Can I wire a outdoor light that is connected to the exterior wall, from a ring main, via a fused connection unit, is this to the 17th edition. Thanks
Reply to Spur to an outdoor light, from a ring main in the UK Electrical Forum area at ElectriciansForums.net
Are you sure the existing outside socket is on the ring, and not already a spur? I tend to place a switch fuse on the ring inside so that the...
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
