Spurring off a ring | Page 2 | on ElectriciansForums
Discuss Spurring off a ring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yes in the diagram S1 is a spur. You do end up with 3 cables into the S2 back box that can be tight. Hence the choice to use a wago box externally.
Yup. However if the feed from DB goes into S1, which then feeds S2, which then is continued onto the rest of the ring - you could in theory wire a spur from either of those twin outlets depending on whichever looks the neatest for the SWA arrangement. Am I correct with that?
Ah, got it. I prefer (if possible) to make all outlets part of the ring by daisy chaining. I think Tel suggested this in post #7 (thanks button pressed). And grommets are good :)
Yes, if the cable was coming into the S2 back box but straight into the terminals of S1, then from there into S2, it would be a ring so both could be spurred off.
Reply to Spurring off a ring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for the advice.
Luckily when I rejigged the socket to fit the fcu next to it, it meant the original ring wiring reached, i put the socket on the ring and took a...
