spurs | Page 3 | on ElectriciansForums
Discuss spurs in the UK Electrical Forum area at ElectriciansForums.net
aberdeen
what is maximum amount of spur sockets taken from a main , the main amperage can be changed easily the wiring is 2.5 and a ring main is not possible without a lot of work as this is a large old house which has been wired this way , there will only be one large consumer a water heater .
You are correct it doesn't, but the OSG is what it is a guide BS7671 is a regulation and imo if someone is in doubt about something, the OSG is where to go and look.
OK, your choice.
It's a bit odd that the OSG adds a requirement that isn't present in the regs. My guess is that it's a hangover from the 15th edition and the writers of the OSG haven't noticed that the requirement has been removed from the regs.
OK, your choice.
So are you saying that as an example 10 sockets in a RFC you can't have 10 sockets as unfused spurs?
No. I'm saying you can have as many unfused spurs on a ring as you like, irrespective of the number of sockets on the ring. I believe that this complies with the current regs.
Yes Handy I can see where you are coming from now, well you live and learn
Reply to spurs in the UK Electrical Forum area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
