Square D QL 2 board with the lighting circuits from two MCBs replace them with single pole RCBOs? | on ElectriciansForums
Guest viewing is limited
Discuss Square D QL 2 board with the lighting circuits from two MCBs replace them with single pole RCBOs? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Reply to Square D QL 2 board with the lighting circuits from two MCBs replace them with single pole RCBOs? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
By code the washing machine needs its own 20 amp single pole GFCI circuit, the dryer needs a 30 amp double pole breaker and using # 10 wire. Your...
