Square head bolt - correct term | Page 4 | on ElectriciansForums
Discuss Square head bolt - correct term in the Talk Electrician area at ElectriciansForums.net
Just asking, cos when my local Homebase closed I bought loads of torx security bolts for pennies, and have used them on garage doors and outhouses, for fixing bolts and hasps, and they come with the driver bit...so far all seems good.
I've only ever used torx on white goods but I'd definitely say they're better.
Torx can be a pain in dirty conditions , the heads easily fill up with crap and in the right circumstances corrode the head . In good conditions they are good.
One day, an inmate from the loony bin escapes and wanders into the local town.
Passing by the launderette, he sees 3 women doing their weekly wash.
Having been celibate for a few years,in the bin, he runs in and has it off with all 3 of them.
He then runs off..
Next day, the local newspaper carries the headline:
NUT SCREWS WASHERS AND BOLTS.
He then runs off..
....that joke has probably caused some lefty southener,to choke on their croissant...;)
....... "robertson"square pan heads 8s x 1 1/2 inch......
[ElectriciansForums.net] Square head bolt - correct term
Every Spark and plumber in Ireland uses these.
They really are wonderful compared to pozi drive.
I've seen them in Canada .. but not sure about USA ?
Reply to Square head bolt - correct term in the Talk Electrician area at ElectriciansForums.net
I tend to write the circuit number on the mcb say every 5th mcb/rcbo just to help make it easier to locate in a large multi way or 3ph board...
Even motorbikes have an earth.
