Squeezing the last Drop
With fossil fuel energy on its way out, I have been trying to come up with a way to save the energy we now use. Here is what I came up with.
May the rock-throwing begin.
comments pro or con welcome
Electric motors are not 100% efficient. Having said that, a 100hp motor puts out 100hp+a small amount of energy not consumed in its operation. It is that small amount that I was trying to capture.
The losses you are trying to capture are lost in the form of heat and sound.
I think the best place to start would be to learn where, how and why these losses occur in the first place.
Once that knowledge is in place the next step is reducing / recovering these losses.
Again, if you think it will work, put your money where your mouth is, make it and test it.
Of which, both sound and heat are largely a result of friction (and a tiny bit of arcing). You could feasibly trap some of the heat by some kind of exchanger and feasibly use some of the air pressure from the noise to drive a diaphragm but all you will ultimately do is create yet more losses downstream in processing that kinetic energy. Newton had this figured out centuries ago - Every action has an EQUAL and opposite reaction. So whilst I applaud you for a drive in efficiency I’d suggest spending your time working on lubricants and bearings rather than this?
You are contradicting yourself. Every action does not have an equal and opposite reaction. There is some loss in every action.
There you go there is loss. Now every aspect of science even so called settled science is and should always be challenged. The challenge here is how to efficiently recover those losses while not spending more time/money/energy than it would to just "accept" those losses.
Edit to add - the total energy output including losses proves Rockingit and some other mad scientist from a while back are indeed correct "every action......."
justcurioustwo,
brianmoooore,
