Stair lift | on ElectriciansForums
Discuss Stair lift in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello all,
could you tell me if a stair lift needs it's own dedicated circuit or can it be run from a spur off the ring.
Thanks Gerry
Stair lifts allow the freedom of movement crave. You can reduce the wear on ankles, knees and hip joints. And I don't know about dedicated circuit of Stair.
Reply to Stair lift in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All, In need of some advice on what is and isn't allowed under regs. I'm extending a circuit in my house so I can install a socket on the...
I like the plan. Best of luck.
