Staircase Timer Switch on LEDs | Page 2 | on ElectriciansForums
Discuss Staircase Timer Switch on LEDs in the UK Electrical Forum area at ElectriciansForums.net
Surrey
Made a bit of a boo boo and have replaced 10 standard light fittings in a stairwell for LED's without thinking about whether or not the staircase timer would work with it. It didnt!
Can anyone recommend a staircase timer switch that will work with 320w of LEDs? Ive searched on line and come up with an Eltako TLZ12G which can handle 400watts but then puts in a disclaimer that this needs to be dimmable LED.
Any suggestions greatly appreciated.
Try this BELBEN make of staircase timer which is designed to operate LED lamps by incorporating zero crossing switching solid switches which are suited for controlling capacitive loads/leading power factor loads such as LEDs. - Staircase light timer switch ELPA 6 plus.
See:
LED-compatible time switches & staircase light timer switches - https://perfect-led-dimming.co.uk/time-switches-staircase-light-timer-switches/
It's specification is:
For more than 10 years, electronic staircase light time switches from Theben have already been equipped with a zero-cross switching
  • Zero-cross switching
  • LED switching capacity:
  • < 2 W: 55 W
    2-8 W: 500 W,
    > 8 W: 500 W
Reply to Staircase Timer Switch on LEDs in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
