stand alone rcd | Page 2 | on ElectriciansForums
Discuss stand alone rcd in the Electrical Tools and Products area at ElectriciansForums.net
Your not wrong TPES
At least the extended or altered part must comply
Rcd and Bonding( unless the bonding can be excluded) to be installed
Ha! I just noticed your old name
Got fed up of it did you?
Yep fed up of the old name.. Too well known..
As far a stand alone RCD goes, if you cannot find an affordable RCBO that fits in current board, then an RCD FCU is always an option for a lighting circuit, and they cost about £12.
I have done this before and labelled it with a marker, obviously not a perfect job but for £12, if it makes the job comply and you feel better than it's well worth it.
Reply to stand alone rcd in the Electrical Tools and Products area at ElectriciansForums.net
I would C2 this, cable is not suitable for the environment its installed in, we would C2 a socket for equipment likely to be used outside , cable...
