Stapling low voltage cables | on ElectriciansForums
Discuss Stapling low voltage cables in the UK Electrical Forum area at ElectriciansForums.net
Grimsby
Witnessed today a security company staple all his Cat 6 cables, coax and alarm cables on a 1st fix new build with un-insulated clips, exactly like virgin media etc install there coax on your skirting board.
Surely this is wrong or just bad practice? Asked him why and he just said there’s nothing wrong with it and they do it on every job.
What’s your opinions?
I do it , do think I'm going to f***king put a clips every time
I put alarm cables & bt cables/ sockets ,
On data cables I'd only use clips where there was no alternative and then use "overlarge" staple / clips (so as not to crush the twisted pair).
Data cables tested with a cable analyser (such as the Fluke DSX Series) for certification, may fail after being clipped too tightly.
I work for a security company and staples is common for alarm cable, mainly on joists in lofts. Can look quite neat when done right.
I wouldn't use them on cat 6 though. Can imagine that causing issues down the line...
Reply to Stapling low voltage cables in the UK Electrical Forum area at ElectriciansForums.net
